Originally Posted by MPaulHolmes
If anyone wants to learn ExpressPCB (which is free, has no size limits, and is pretty easy to use), they could convert the layout that is in PDF form to ExpressPCB layout format. Basically, all a person would have to do is look at the picture of the top and bottom layout in the PDF of revision 2C, and copy it to ExpressPCB. The 6 pin thing for serial programming would need to be mirrored (there was an error) but that's no big deal. Then people can add whatever changes people want to add. The software is here:
ExpressPCB - Free PCB layout software - Low cost circuit boards - Top quality PCB manufacturing
Ok, Downloaded ExpressPCB, I will try to find some time this weekend to go trough all datasheets and get SOIC infos for all components...
Can you please post the fixed (The 6 pin thing) REV 2C schematic here or on the wiki ?!
Is the BOM final ?!?
Thanks
