Originally Posted by Christ
No drilling... use PC7 Epoxy, and epoxy some threaded stand-offs in the deep places around your rim, then get it re-balanced with the hardware installed. This will keep your original rim integrity, not damage anything (except the finish, maybe), and allow you to remove them later if you wish, without permanent effects to the wheels.
This is a good idea which I havent seen much of. I will most def keep it in mind.
Tape might win on this one. Bleh
