Old 06-21-2009, 03:31 AM   #1 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Haven't seen this one around... "Smart Plugs"
Anyone seen these?
SmartPlugs.com - Home Page (Flash)
Smart Plugs, Smart Plug by kNew Corporation
The SmartPlug™Catalytic Ignition System
Basically, it's a catalyst that auto-ignites fuel under heat/pressure, is compatible with many fuels, initially works like a glow plug, then stays "lit" while under load with no electrical requirement... It's supposed to be a replacement for your complete ignition system, and allow "Hyper-Lean Burn" which apparently is burning lean enough to not have NOx emissions. This, I gotta see.
The purchase link in the "store" is down, as they're "gearing up for higher production" at the moment.
US Patent No: (Can't find it yet.)
