yea, pretty much. It's really just the places between each gear that gets worn down.
I've decided it cancels out either way, since at the bottom of the hill in gear you'd have to use a little more fuel to get back to the speed you'd have been if coasting in neutral, but you have not had to bother with shifting, etc.
I don't know why, and I don't know how come, but I slow down when I put it into neutral. If I'm going 55 at the top of a hill, at the bottom I will be going over 65 while in gear, but only hit 60 while in neutral. Both tests I have done on the same hill. It makes me wonder whether my engine uses the same amount of fuel whether it's in neutral or in gear
![Confused](/forum/images/smilies/confused.gif)
