Im putting mine together now but I don't know what number values I should be measuring, or how to hook it up..
I think if I just leave it at 0-5v it will work but I would rather be more specific. Do you think the honda insight uses the same wideband 02 sensor as my 98 hx? I know the insight goes leaner than the hx, so the number values will be different but can I at least follow the wiring diagrams do you think?
Thanks
