Old 06-22-2009, 02:47 AM   #16 (permalink)
LeanBurninating
EcoModding Punk
LeanBurninating's Avatar
Honduh Power - '98 Honda Civic HX
90 day: 44.37 mpg (US)
Current intake setup:
I like it this way versus stock because I am sure it flows easier and there are no big sound boxes. I just put this one on tonight, Im going to see if my numbers changed from the one that I swapped out (basically the same thing, except all pvc, no metal, and smaller inside diameter) and sooner or later I will try the stock intake again.
I will also cap off those air ducts from the bumper towards the filter, nice call wonderboy.
On a side note, do you think it will make much difference to relocate the breather hose and temp sensor? Will putting them further upstream yield less turbulence at the tb?
