Originally Posted by blackpanther-st
Mosfets would be much preferred for this circuit as the voltage differences will always be minimal between the two packs.
Black Panther, this discussion has moved to another thread "Open ReVolt as Charger". But with the setup you mention, how would I control the amount of current that the lower C pack delivers? The purpose of the controller was to not let the lower C pack go above 70A. If the two packs were just connected through Mosfets, I wouldn't be limiting that. In that case, I might as well just do away with the Mosfets altogether and just connect the two packs directly to each other.
Bill
