Old 06-23-2009, 09:34 AM   #9 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
this is why good compressors have fins on the line before the air goes in to the tank, but the tank is also a big steel heat sink so really you are putting cold air in the tire unless you have been using the compressor alot and it's hot, hand pumps also heat the air, it's the compression that does it.
