Old 06-24-2009, 08:05 PM   #13 (permalink)
Jetta90GL
Originally Posted by Christ View Post
The next choice is a Ford Ranger, which comes equipped with a 2.3 4 cylinder. The engine from a Ford Escort (1.9 or 1.6, either one) will fit directly against that transmission. You use the flywheel and pressure plate/clutch disc from the Escort engine.
I don't know if the diesel engine is the same bellhousing from a Escort as the regular gas engine or not, so I can't say if you can use that one.
The 2.3 in the Ranger, Pinto, Turbo Coupe, and Mustangs are not the same as the 2.3 in the Tempo. Tempos and Escorts have a transverse engine with a transaxle.
