AutoZone sells it for $243. There is an epoxy stick you can use for temporary repair or else you would need to have it sent out to be cleaned (in and out) and welded. Do NOT attempt to weld it yourself..
Does it only leak when full? Maybe its just the ring that seals the pump/fuel level sender into the tank.
1996 Pontiac Bonneville SE 3.8L V6
