Old 06-27-2009, 07:07 PM   #7 (permalink)
vinny1989
Assuming its a manual gearbox, there is a little trick which may work:
From neutral with the clutch down, shift into second then directly into first. Do not let the clutch up until in first gear.
Its works in my little Punto with a damaged/worn synchro on first.
If its an auto - ignore this post!
