Old 06-29-2009, 01:59 PM   #13 (permalink)
DonR
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
It's called an accusump.
Canton Racing Products
1, 2 & 3 quart accumulators. You would have to insulate it yourself. Electric valves are available.
Normally they are used with drysump oil systems with a large resovoir. The small cooling resovoir may present a problem. There may not be enough volume to empty the accusump.
A system with a pressurized "overflow" bottle may be the way to go. You could increase the size of it with an auxillary tank with an upper & lower hoses. You need to make sure the tank has air in it.
Don
