Old 07-02-2009, 01:18 PM   #8 (permalink)
RandomFact314
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 23.24 mpg (US)
Originally Posted by wagonman76 View Post
I think the Viva 2 is a 35 psi tire, which to me means it is a "cheaper" tire. The sidewalls aren't as good as a 44 psi tire. That's why they're rated to hold less. I have blown sidewalls out and had tread separate on many 35 psi tires, but never on 44 psi tires. The rears on my Celebrity are still the same tires I bought for the wife at the time back in 2002. I don't drive fast or aggressive, but with Michigan roads I might as well just sit in the driveway and beat the tires with a large sledgehammer, it'd give the same effect but cost less.
If you drive reasonably and your roads are good, you should have no problems.
ACTUALLY they are 44max psi......
