I thought the fins on the Alfa BAT concepts increased stability. And I thought aircraft tail fins were used with a rudder to counter yaw effects (and help turn the aircraft). No reason a vertical fin couldn't be employed with a rudder, if necessary. Your small increase in drag to counter potentially dangerous destabilizing crosswinds would be nothing compared to a traditional high-drag shape.
