What is the opacity test?
Yes, it's a good idea to do the coast-down test at as high a legal speed as you can: even if you don't drive at that speed, the higher speed helps to show small changes in air drag.
Nifty idea with the battery and solar panel, too. Hope it brings you net savings.
