Old 07-07-2009, 06:56 PM   #197 (permalink)
Matt Herring
Matt Herring's Avatar
Bone's 2010 Prius - '10 Toyota Prius Black
90 day: 56.78 mpg (US)
I asked the same question over at priuschat and I was told the only way to monitor inverter temps was with Can-View. SGII cannot be programmed with XGuage to monitor inverter temps (bummer). Kind of flying blind on grill blocks...scary!
I'm not sure on the inverter coolant but I would guess it is circulated through a separate radiator as the ICE engine is able to operate at a much higher temp than the inverter and running ICE coolant through the inverter might not be at a low enough temp to cool it sufficiently. Just a guess though.
