That sounds promising Christ. I was wondering on a convenient way to implement it. The downside of doing it the simple way(coil magnet in the springs) is you'd have to use a diode to make sure the current only goes one way(your alt does something like this) so you'd lose your energy production either up or down. . .
The air shocks sounds like a good bypass method for the entire process.
