Old 07-08-2009, 03:35 PM   #50 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by dutchboy View Post
What kind of price range are shocks that will have the fittings for doing something like this?
Post #40. Air shocks have a single inlet/outlet fitting on them. You'd have to tee off it and put check valves in the lines, so that the compressed fluid (air) could only flow in one direction through the circuit.
They're about $70 for a pair, with the install kit (tubes, fittings, etc.).
You can find a good set at AutoZone.
AutoZone.com | | Shock/Strut - Rear | HIJACKER AIR SHOCKS
