Originally Posted by tasdrouille
Why don't you try swapping the O2 sensors? If your front O2 sensor is the culprit the code will change to tell you your cat is bad, but performance should be restored when the engine is cold.
some cars use completely different sensors for the front and back...
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
