Old 07-12-2009, 12:38 AM   #12 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Christ -
Originally Posted by Christ View Post
Super glue? Seems like you could just paste some glue over it and smooth it out with a tongue depressor to get rid of the overlap necessary... or taper both edges of the pie cut to fit together, then glue them before installation.
AAMOF, if you're careful about where you make the pie-cut, and you're using corrugated plastic, you can just stick a couple plastic pins in the corrugation to hold the pieces together.
Yes, you could also cut a small pie piece that you use as a base (on the back) to glue the cut edges together.
I didn't use coroplast because I liked the thinness of the plastic sign. I speculated coroplast wouldn't bend as well (probably not true for this application, but that's how my brain works). I also don't like cutting curves in coroplast. Gluing coroplast together with pins is a cool idea, though. Gonna save that idea for later.
Right now I'm happy with the results. The real test will be my commute to work.
CarloSW2
American Solar Energy Society
