Originally Posted by squiggles
Picky I know, but NAND gates are digital
I know they are "digital", but the rise and fall times are so slow that they might as well be analog.
Paul, I also second that you should have the PWM set to 0 while the Over Current is resetting the flip flop. The PWM may be keeping the pin high enough to stop the flip flop from resetting.
