Old 07-13-2009, 11:31 AM   #1995 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Problems COMPLETELY SOLVED!!!!!! WILL EXPLAIN LATER! MUST GO TO SCHOOL!!!!!!!!! hahaha! ya!
Basically it's perfect now. No hardware changes necessary for anyone (well I had to replace my bad ATMega8 since I ruined it in the testing)!!!!!! Coding mistake!
OK, I'll just say it now:
I set PB2 as output, but then in InitPWM(), I accidentally set PB2 to input when I do this:
DDRB = 0b00000010;
I accidentally did = instead of:
DDRB |= 0b00000010;
So, PB2 was set as an input, so when I would try to use it as an output, since I would have to pulse it low, it would say to me, I WILL NOT GO LOW AND RESET THAT OVERCURRENT EVENT! I'M AN INPUT!!! It was really quite rude, actually.
EXPLANATION OF overcurrent diode et. al. soon! must go to school! ya!
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
mpgmike (01-12-2022)
