Old 07-14-2009, 10:46 AM   #2 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
"low profile" will reduce the efficiency of the fan, and reduce the fan's CFM per RPM. But if you're cramped for space, do what you have to do.
The answer to your question would be "a truck". Probably a truck with a sideways engine. Minivan? Dodge Sprinter? Head on down to the U-pull and check it out. You'll probably come back with two small fans instead.
