Old 07-15-2009, 01:53 PM   #12 (permalink)
TheSGC
Originally Posted by AmpEater View Post
First of all, weird. I'll bet your background is more in machining and/or auto work, whereas mine is electronics. Guess its all relative.
And excellent point about the cost of lead....gone are the days of "cheap lead now, lithiums later"....if you're dropping 5-6k on batteries anyway......
AmpEater, my background is Electronics! Machining was quite simple enough, using AutoCAD to design up everything took a bit of time, but not much.
What killed me about the electronics was that most of the connections were not compatible with each other, and having rewire chunks of the cars electrical because they were old and would quit out on me.
Wet lead acid batteries are still cheap, but AGM and sealed cost nearly as much as lithium. My next pack might be 8 volt floddies, then Lithiums, unless lithium prices drop like a stone next year, which is possible.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
