Old 07-16-2009, 06:11 AM   #13 (permalink)
Kevin Johnson
Originally Posted by ConnClark View Post
Typically these things are only effective under hard acceleration, and if thats the case your fuel economy is out the window anyway. They provide no benefit under cruising conditions. I suppose they might have some benefit if you go up very steep hills a lot but thats it.
Hi,
I make the scrapers referenced. There is a lot of misinformation out there.
For example, in ConnClark's engine, Mercedes engineering includes five crank scrapers in the floor of the pan.
In my Mercedes diesel (300 SDL), I often cruise at 3000 RPM. That is well within the effective range of a scraper at cruising conditions.
