Old 07-16-2009, 05:17 AM   #14 (permalink)
Kevin Johnson
Originally Posted by ATaylorRacing View Post
Or, you can run 1/2 qt low on your oil to keep the crank counter wts from splashing into the oil. I do this on the cars I race and they are a tiny bit quicker AND helps eliminate oil foaming.
Not too many people have taken the time to actually measure how much oil is in the pan of a G10 or G13 engine. If you do, you will find that the running oil level is just beneath the windage tray which also acts as a slosh baffle.
Running a drag or road racing car definitely requires you to look at the oil level and sometimes you need to reduce it.
