Originally Posted by MPaulHolmes
I disabled all pull up resistors (Thanks, JayC), and the dang blasted thing still didn't work! monkey poo! I thought that would be it for sure! But then I added a temporary pull down resistor from PIN 5 of U5B to Ground (is that redundant? hehe), and it seems to work! Maybe I'll just solder a 2 or 3k resistor there and test that monkeypoo out!
just read this and haven't read forward yet, so maybe you have it now, but this sounds to me like you had an unexpected load / resistance imbalance. The added resistor may be fixing the problem, but I would look further to find the cause of the imbalance; you may just have to change the value of an existing pull up of pull down.
