Old 07-17-2009, 02:50 PM   #43 (permalink)
NiHaoMike
Turn off the water heater and close the valve. Then slowly open the valve while listening for water flow. That will confirm if there's a leak.
If you suspect someone tapping power but other steps don't remedy the problem, my solution would be to disconnect all devices, turn off the main breaker, borrow a 240v (or more) inverter or generator, and use it to apply 240v from each hot to neutral.
Another solution is to leave the water heater off at all times and cook some water on the stove for showers.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
