Originally Posted by tasdrouille
Use an higher gear! Bump start earlier if need be.
Thanks tasdrouille, I think I need to start the bump farther back, I am nearly at a stop and it makes the engine shake.
I don't want to use 2nd gear, like christ says, because regardless of the condition of my tires (or my light rear end), I find that moving into 2nd gear at 20 mph causes the synchros to "whizz", better not...
I'll try starting the bump farther back...I can do it smoothly usually, but every so often it gets out of hand...
Chipsndukes
