Paul that must make it so much easer to adjust your code when you can see the reaction data like that.
It would be great if you could get your Bata testers to send this type of data to you from different motor / vehicle weight applications. Then you could write some presets or a better general setting. Even better yet find a high and low range and program a simple user accessible setting to vary the response to anywhere between the high and low points. The user just picks their motor and vehicle weight from a chart and enters an appropriate value for their combination and they would have a controller tuned for their particular application simple as that.
