Clutchless
jmcginley
My 1985 Camira is clutchless, I can change from third to fourth or fourth to third by just lifting off the throttle, I only need second gear on a steep hill following a tight bend for this I try to anticipate and select second while stopped, adjusting revs is difficult. I have been using a Curtis 1231c and after that blew up a Logisystems 144V controller, with these I need the lower gear for low speed on a steep rise, I am hoping that Paul's controller will be better.
John
