Originally Posted by Daox
Well, copper has a much higher melting point than aluminum (1,984F vs 1,220F), and turbos use aluminum housings. I think we'd be ok. I'd be more concerned about the resins inside that hold the windings together.
I dont know what turbo's you put on your car but all the turbos I know the housing must be made of stainless steel, cast steel, or cast iron due to the fact that they have to withstand up to 1200 degrees coming from a high out put engine.
if you do see a turbo housing made of aluminum be sure to tell me so i will remember not to invest in it.
