Old 07-20-2009, 12:58 PM   #22 (permalink)
JackMcCornack
JackMcCornack's Avatar
Originally Posted by nubbzcummins View Post
JackMcCornack: Could you explain pumping losses that occur with my setup running in boost other than at idle and going down steep grades?
I'll give it my best.
Energy is required to turn the engine over. Some of that energy is used to pump air through the engine, whether or not that air is used in combustion. Your Cummins and my Kubota both ingest more air than they need for complete fuel combustion, except when they're operated at full power.
At idle, the combustion process produces exactly enough power to keep the engine running--enough to overcome the engine's friction losses and pumping losses. Hotter air (less dense) reduces pumping losses, and for a given idle RPM, less fuel is required with higher than ambient intake temperatures, and I'm thinking that holds true from slightly higher power than idle all the way up to somewhere close to full power.
Seems like maybe I should put some temp sensors in my turbo in/out airstreams and check. If it turns out I'm full of bleep, I'll sure let y'all know.
Also how does warmer air make it more efficient vs cooler air which makes more power and requires less boost to achieve the same required power to overcome all drag/losses on the vehicle?
A lot of the advancements in power come from auto racing, which is normally defined by engine displacement, and the max horsepower per cc limit is almost always determined by how much air mass you can get into the engine. Cooler air = higher density = more mass = more potential horsepower. Maximum power comes when all the air is used in combustion, max economy comes when all the fuel is used in combustion.
In our engines, at most power settings, we have all the air we need. Your and my engines don't even throttle the air, ours vary the power output by adjusting how much fuel gets squirted in to the system. I don't think cool air makes more power until the engine starts running short of air. But I'm also thinking, maybe I should set up an air intake with a flap, sort of like the carb heat flap on ICE airplanes, so I can see if my boost goes up in cruise when I switch to warm air. If so I'll be surprised, but life is full of surprises and one more won't hurt me.
