Old 02-27-2008, 03:04 PM   #21 (permalink)
trebuchet03
MechE
The Miata - '01 Mazda MX-5 Miata
^^ Repair it with fiberglass on the inside.... To fill the crack on the front, apply tape over it (to conform to shape), then fill with resin (polyester won't yellow in the sun which may be a good attribute for you). Then wet sand with super high grit so it appears clear.
That is, if you want to repair it.
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
