Thread: Toyota Aygo
Old 07-23-2009, 04:18 AM   #15 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by FlightlessNinja View Post
The lower grill is already partially blocked on the left hand side but the honeycomb pattern i'm sure is not helping with the air flow so i'm going to smooth over this and help guide the air towards the radiator.
How about guiding the air away from the rad? The radiator and its grill are a partial air trap, so directing more air onto it may increase drag. Directing air to the side or top should be better. Also, you could probably cover the other end of the grill, diverting that air to the other side. How much? You'll find out by trial and error. Cover maybe the whole right half with cardboard and drive around with that. If you notice that the temperature is too high and the fan keeps turning on, then shorten the block by 10cm. Mid-summer is the best time for adjusting grill block size.
