Ah, you are using two contactors?
I had planned to use only one on my build.
The contactors should be able to isolate grid voltage then, which they probably aren't made for, but may do.
Used with a ground fault circuit interrupter the charger should be pretty safe even if something bad happens, like arcs jumping in the contactors.
