Old 07-25-2009, 09:31 PM   #150 (permalink)
NiHaoMike
Originally Posted by bjn View Post
Ah, you are using two contactors?
I had planned to use only one on my build.
The contactors should be able to isolate grid voltage then, which they probably aren't made for, but may do.
Used with a ground fault circuit interrupter the charger should be pretty safe even if something bad happens, like arcs jumping in the contactors.
The contactors should not arc if they're sized right and switched at zero current. (Which means stop the motor before disconnecting and precharge before connecting.)
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
