Old 07-26-2009, 12:42 AM   #38 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
I always downshift in auto or manual, before I ever use the brake, even on flats. Engine braking is a more efficient way to bleed off some speed. If your engine won't bleed off enough speed fast enough, you use the brakes in addition to the engine.
I specifically make all attempts to only use the brakes while stopping completely, whenever possible. Even then, I slow down as much as I can, for as long as I can, with just the engine's compression.
