Old 07-26-2009, 12:58 PM   #1 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Orzeszek - '18 Škoda Citigo Ambition
Roofline/Kammback transition - sharp or rounded?
Say the roofline in the back of a car is more or less level (black). Should the Kammback abruptly start dropping at a 11 degree angle (green), or should there be a rounded transition first (red)? (The angles are exaggerated)
Intuition whispers that the sharp edge between roof and Kammy would cause detactment of airflow (blue):
while a rounded transition would help guide the airflow smoothly down the Kammback:
On the other hand, maybe intuition isn't always the best tool in aerodynamics, and maybe the 11 degree angle isn't enought to detach airflow?
ID:	3919   Click image for larger version
ID:	3920   Click image for larger version
