Originally Posted by outsidethebox
There is no reason we shouldn't have a 300 to 500 MPG car right now. They have had it wrong all these years. It will be easy to build but you have to realize what's wrong with what we have. Look at it differently.
That's a great idea! You should do that! It's easy!
Why haven't you modded your Neon that way? Have you owned it since new- 14 long years of using so much gas???
Lessee... pull the EFI off and stick a carb on it... insulate the engine compartment... throw the transaxle away and put a chain in there... put heat exchangers on
everything... a few other lil things and yer set!
