Old 08-01-2009, 03:10 AM   #46 (permalink)
Kevin Johnson
Recently I was trying to help someone with an efficiency project and he proposed doing this and many other things to an engine. Too many good ideas and not enough time or money and the project died, sadly.
Originally Posted by Christ View Post
You wouldn't be referring to the R18 Honda engine would you?
They offset the crank's center line in relation to the cylinder bores so that the force of combustion was pushing directly down on the cylinder and rod assembly (approximately) instead of attempting to force it at an angle. I have a D15 Honda block that I have considered doing this with, by having it milled to fit a D16 crank, but milling it with a preference to one side of the bearing journal. The problem with doing so is that I'd also have to custom build the rear main seal carrier, and the oil pump, since they're both designed to be used in standard design.
I don't think either would be too much of a problem, since the oil system could easily be converted to an external pump, with a blockoff plate and seal on the front of the crank, and the rear main seal is just placed inside a plate that could easily be redesigned and milled.
Maybe I'll try this in the next couple years, if I ever get the money to have the engine milled the way I want it.
