Old 08-01-2009, 03:20 PM   #32 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
A lonely messenger
[QUOTE=aerohead;119009]---- The template respects streamline flow with an economy of structure and literally guarantees attached flow,at least if you don't cheat the minimums.----------- YOU CAN make the body with higher fineness ratio,I just want everyone to understand that there will be a small penalty to extra skin friction.
I agree that it is good to avoid extra skin friction, but when only one study suggests that flow can stay attached to a shape at 2.5 : 1, and hundreds of tests at a more suitable Reynold's number disagree, I want to see some tuft tests. In the NASA tests for streamlining trucks, you can see a tailcone extension eliminating a Kammback, while increasing the angle a bit, and the tell-tales show separation there, at an angle that is still less than this "ideal."
