Old 08-02-2009, 10:28 AM   #58 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Anyway, I think pressurizing the intake is generally counter "eco", in the general sense.
Assuming you are cruising on the hiway in a "typical" car, you have way too much power to begin with. You probably are not in the peak bsfc zone. Increasing the density of the incoming air means the throttle is more closed, and the pressure drop across it is larger.
So in lieu of putting in a smaller engine, one strategy is to detune the engine, i.e. hai. (along with gearing and aero and etc). Bring peak torque down and open the throttle more. If the crankcase is a "closed" system, reducing pressure should affect the air mass in the case as well.
Though if you are taking air from an already low pressure spot, it adds to the pressure differential of the vehicle, to reduce the internal drag of the engine. Don't know if that is a wash or not.
If I had to guess, I would think that reducing crank case air density would move the bsfc peak up the rpm band. But could not sufficiently explain it.
