Originally Posted by Ryland
if you go to small the you limit you brake rotor size, so I would stick with 13" or so.
I won't have brake rotors, so that's not an issue. I'll be downsizing my hub motors, but I don't believe that to be an issue either, as my estimated 65mph cruise will be 10KW. Acceleration can be dealt with through water cooling.
