Old 08-02-2009, 09:33 PM   #17 (permalink)
SVOboy
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
483 and 776.5 +/- 2mm for the crx axles.
Think the axle nut might be 22x1.6
So, length is only 1cm off on one side, if the spline count is the same or the hubs can be swapped, what do people think about using the insight axles (I could position the engine to split the difference so it's only 5mm different on each side)?
