Wow, thanks for the many welcomes.
cfg83
Unfortunately the Insight is mostly plastic and aluminum, so magnets don't help much. My test adhesion piece will need to cure for several days before I put it to the wind tunnel test.(My nephew has access to the Worcester Polytech wind tunnel). I also bought some 3M acrylic adhesive foam tape, that is supposed to bond metal to metal as well as rivets, so that will be my back up plan. 5 yards for $48, it better be good.
krousdb
I remember meeting you and Wayne Gerdes there for the first time.
I hope to get out to Hybridfest again this year, and will drive out if possible.
I had a good time last year.
Mike
