Old 08-03-2009, 10:07 AM   #60 (permalink)
Alex99
I've seen a low budget solution on the web and multiple froums that uses intake manifld vacuum to evacuate the crankcase. Its called "Krank vent" and is basically 2 special checkvalves that are used in the original PCV system.
Do a search in the web and you'll read more. I'm also still investigating if this is a good solution.
Welcome to ET Performance !
