Old 08-05-2009, 12:17 AM   #44 (permalink)
swoody
Certified Duct Tape Tech.
swoody's Avatar
Slow Ride - '00 Honda Civic DX
90 day: 46.32 mpg (US)
Originally Posted by Christ View Post
You can actually almost redline the engine without damaging it as long as you're not on the throttle.
If you're worried about RPMs, put the transmission in 2 and run the Jeep up to 50, see what your RPMs are.
If you have a 3 speed, you're fine. I use 2nd gear on the highway to slow down.
If you have a 4 speed, you'll be closer to overspeed with 2nd gear, but I'd imagine you'd still be fine. First thing to check is that you can't manually disengage OD. If you can, do it first, before downshifting.
Ah, great info, thanks! I guess I'll have a run on it, and see how high it goes in 2nd. If I can manually disengage OD, should I just disable it, or would I have to disable it and then downshift to 2nd? Will just disabling it give me any engine braking?
~ If you don't jump with both feet, you don't move at all ~
2000 Civic DX :: 52/50 psi :: Free Warmer Air Intake :: Duct Tape Aero
"Spare the duct tape, spoil the job."
