Old 08-05-2009, 09:48 AM   #51 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Clev -
Originally Posted by Clev View Post
I can't confirm that that applies to all FI cars.
In my downhill run, the exhaust on the Clunker burbles slightly when engine braking and the vacuum increases slightly (and engine braking increases slightly) with the key off. This leads me to believe that a small amount of fuel is flowing. This is a '90 with PGM-FI.
Yeah, the older the FI car, the less likely it has DFCO (deceleration fuel cut off). I am pretty sure my car does not have it either. With my digital AFR (Air Fuel Ratio) gauge, I can see the AFR go lean when I hit the brakes, but the lean condition doesn't last for the whole brake event, it goes back to 14.7 . This implies to me that the engine is still getting fuel. Also, when you brake in-gear and you approach idle RPM, the fuel is restored to avoid stalling the engine.
CarloSW2
American Solar Energy Society
