Old 08-06-2009, 12:09 AM   #2152 (permalink)
mcudogs
I will add the diodes to the next version controller board. The other way to cut out some of the interference is to make sure that you don't run low voltage signal wiring close and parallel to high voltage / current wiring.
If you need to cross a low current conductor over a high current conductor it should cross at 90 degrees. Also the low voltage wiring should be shielded with the shield connected to earth at both ends if possible.
